Home Forums Products Stompboxes Current draw of dot9 stompboxes? Reply To: Current draw of dot9 stompboxes?
#179139
InfinitiCreati
    Just buy a bunch of 9 Volt 1 Amp power adapters Making Sure Center is Correct polarity, all is well, PitchFactor and ModFactor need 1.5 Amp.
    The half Amp overhead will never shove itself on its own. Current is drawn as needed, not forced
    Current draw is not about matching numbers, its about having enough.
    For Current (Amps) think of the waterpipe’s Diameter, Voltage the Pressure, and you’re good to go.
