Home › Forums › Products › Stompboxes › Power Max with Eventide Pedals › Reply To: Power Max with Eventide Pedals
#179733
InfinitiCreati
    As log as Polarity is correct, Voltage is +-5% of the unit’s spec, and Current mA or A for each power port is Greater-Than the device needs, barring extreme over-budget (Current get drawn by the device’s needs, not pushed into the device) it is all good.
    Your ModFactor? I have the other three also, but they work. The folowing is after a smooth firware update and
    A strange deal that started off fine on Reverb lands me a ModFactor whose Encoder bring the top-left LED on then top-right, then Left 2nd row Right 2nd row, then now more presets are lit. I already have an order to get it fixed, though it seems odd that this appears to be brand new, this would happen.
    1 2<-top row
    3 4
    no more here down
    4 3 <-top row
    2 1
    then no more going down
    numbering is the order they light up per encoder stepping
    yours ever do this?
    my Arturia MicroFreak LOVES Eventide FACTOR Series
    thnx
