Power Max with Eventide Pedals
Home › Forums › Products › Stompboxes › Power Max with Eventide Pedals
    • #179665
      igsxiii
        I own 4 eventide stomp boxes – the Space, TimeFactor, PitchFactor, and ModFactor. Can the Power Max supply power to all four at once, or would I need an additional supply?
      • #179666
        joecozzi
          Yes, one on each outlet set to 9 volts.
          • #179733
            InfinitiCreati
              As log as Polarity is correct, Voltage is +-5% of the unit’s spec, and Current mA or A for each power port is Greater-Than the device needs, barring extreme over-budget (Current get drawn by the device’s needs, not pushed into the device) it is all good.
              Your ModFactor? I have the other three also, but they work. The folowing is after a smooth firware update and
              A strange deal that started off fine on Reverb lands me a ModFactor whose Encoder bring the top-left LED on then top-right, then Left 2nd row Right 2nd row, then now more presets are lit. I already have an order to get it fixed, though it seems odd that this appears to be brand new, this would happen.
              1 2<-top row
              3 4
              no more here down
              4 3 <-top row
              2 1
              then no more going down
              numbering is the order they light up per encoder stepping
              yours ever do this?
              my Arturia MicroFreak LOVES Eventide FACTOR Series
              thnx
          • #179732
            igsxiii
              Much appreciated!
