Home › Forums › Products › Stompboxes › H90 Not remembering the mode i left it in › Reply To: H90 Not remembering the mode i left it in
#180294
joecozzi
    Hello Boynifel,
    The Programs button is used to enter a menu where you can search for Programs. It’s not one of the three play modes – Select, Bank, or Perform mode. The second image shows you are in Bank mode. If you press and hold the SELECT button, you’ll go from Bank mode to Select mode, which will display the name of the program similarly to your first image without needing to press the Programs button. The pedal will only boot up in the last mode you used; it will never boot up in any of the menus like Programs, Routing, Presets, or Parameters.
