Home Forums Products Stompboxes H90 IOS and mac OS software three button Hotswitch controls Reply To: H90 IOS and mac OS software three button Hotswitch controls
#180430
    The “parameter edit mode” in H90 Control is not the same as engaging a HotSwitch in PERFORM mode. If you are in parameters edit mode on the pedal and you press and hold one of the P/A/B LED buttons, this will enter “parameter edit mode” on the pedal, and allow you to map parameters to the HotSwitches. This will be reflected on the pedal and in H90 Control.
    Can you please elaborate about the last point you made? There is no action that requires pressing all 3 footswitches simultaneously. Turning any of the HotSwitches OFF will change the UI of H90 Control from HS1-3 “parameter edit mode” back to “PGM”.
