Home › Forums › Products › Stompboxes › H90 IOS and mac OS software three button Hotswitch controls › Reply To: H90 IOS and mac OS software three button Hotswitch controls
No need to apologize. I understand that this element of the UI in H90 Control can cause confusion because of the difference between activating a HS and using the parameter mapping mode of a HS.
On the pedal, if a HS is mapped to a footswitch in PERFORM mode, that LED will be turquoise when the HS is OFF, and red when the HS is on. This is the best visual indication for keeping track of the state of your HotSwitches. All 3 LEDs being turquoise would indicate no HS being active (PGM mode).
We may consider something in H90 Control to improve this UI, but we have nothing planned at the moment. My best solution would be using the pedal itself whenever you want to activate a HS, and only using H90 Control for the parameter mapping, not as a live performance tool for activating HotSwitches.
