Home Forums Products Stompboxes Request – H90 inserts always on (whilst turning program off) Reply To: Request – H90 inserts always on (whilst turning program off)
#180606
    This thread is a bit old and we have implemented a feature called AB Only Bypass that allows you to bypass a Program and keep the inserts active. This should resolve the issue that all of the users here had requested.
    You can turn this setting on by going to System > Bypass > AB Only – https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/system-menu/global.html
    Does that resolve your issue or are you requesting something else?
    There is no “global” insert option, you will need to go to the routing page and enable an insert to be active, and then save a Program if you want it to load with that insert active.
