Home Forums Products Stompboxes H90 Wet/Dry/Input Level Blend Expression Reply To: H90 Wet/Dry/Input Level Blend Expression
#180874
joecozzi
    A variation on this is using a parallel routing and leaving one side free of any presets as your dry path and putting one or both presets on the other side. Same thing, map the expression pedal to the input gain of the first preset on the effects path. In this case the effects should be set to Kill dry so as not to double up on dry paths.
