Home › Forums › Products › Stompboxes › Dual path + insert routing w/o changing cable configuration? › Reply To: Dual path + insert routing w/o changing cable configuration?
April 13, 2024 at 6:33 pm
#180990
<span style=”font-size: inherit;”>It’s an old thread, but I just found myself in the same situation so I’m</span><span style=”font-size: inherit;”> glad I found this!</span>
Curious what loop selector you used. I’m going to try it with an LS-2 which I think should do the job.
It would be ideal if this routing could be handled inside the H-90. I’m going to post around and maybe post it as a feature request if it’s not already been asked.
