Home Forums Products Stompboxes Dual path + insert routing w/o changing cable configuration? Reply To: Dual path + insert routing w/o changing cable configuration?
#181013
johnbegone
I’m using a loop selector made by Saturnworks.  He’s a small builder and he’s helped me with a bunch of small projects in the past – but this one happened to be a stock pedal he makes that I picked up on Reverb.  Hope that helps.  The Boss LS-2 will work fine theoretically.  I’ve had issues with tone suck on those in my long ago past (haven’t tried in the last 10+ years so grain of salt..) which is why I went with the Saturnworks as passive and true bypass.  Since only half of the stereo signal will be passing through it, it’s super important to keep your cable path and anything else in the chain at a minimum so the signal stays true and in phase.
