Home › Forums › Products › Stompboxes › Dual path + insert routing w/o changing cable configuration? › Reply To: Dual path + insert routing w/o changing cable configuration?
April 15, 2024 at 11:09 am
#181016
Hey, thanks!!
I tried with the LS-2. It worked fine for stereo when both presets were together but I couldn’t get things to work right when trying to use the presets at different places in the chain.
I’m using a Fender ToneMaster Pro and I know there are some acknowledge issues with its Fx loop behavior, but I also note what you mention in your last sentence. I main up Saturnworks, I’ve gotten good stuff from them in the past
thanks again!
