Home Forums Products Stompboxes H90 New Preset – how to? Reply To: H90 New Preset – how to?
#181043
    A – Custom Preset.
    • In H90 Control, load up the Program with Custom Preset A in it, and Save to Library.  10.3.2 Parameters Edit Menu – Item 12 – in the link below:
    https://cdn.eventideaudio.com/manuals/h90/1.8.5/content/h90-control/edit.html
    B – Existing Algorithm B
    • Load up the Program with Existing Algorithm B in it, and repeat the same process described above in Item 12.
    Now load up a fresh INIT Program.  Go to the link above, down to the bottom – 10.3.5 Preset Library – TIP.
    Find & select Custom Preset in Preset A, then Existing Algorithm (preset) in Preset B.  Give it a unique name, and SAVE Program.
    There are other ways to do it as well.  For example, I favor a combination of Preset selection on the pedal with the file management & editing in H90 Control.  But you can accomplish the same in either pedal or app.
