Home › Forums › Products › Stompboxes › mono loop and stereo out › Reply To: mono loop and stereo out
#181252
    You can follow these instructions for 1 mono insert, just ignore the instructions for connection the 2nd mono insert. Connect H90 outputs 1-2 to your stereo monitoring destination.
    https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/setup/two-mono-inserts.html
    Note that if your mono insert is at the very end of your insert routing signal path, final output will be summed to mono. If both outputs 1-2 are connected, any presets before and after the mono insert will process in stereo.
