Home › Forums › Products › Stompboxes › Tape Echo with Expression-controlled Input › Reply To: Tape Echo with Expression-controlled Input
April 29, 2024 at 1:20 pm
#181655
JDrage
Thanks for the suggestions. You’re right that the second option doesn’t give the right results, the expression pedal affects the output of the sound from the loop as well.
With the first option, the loop output continues, which is great. But I think I forgot to mention that I have a Series config with another algorithm in slot B (Crystals). I want the output to persist when the pedal is heeled. When targeting the input gain with the expression pedal, the input does not pass through to the B algorithm. Is there a way to accomplish this?
