Home Forums Products Rackmount Higher Resolution Volume Pedal Reply To: Higher Resolution Volume Pedal
#181851
gustebeast
    Thanks! I can see the decimal gain values and it’s smoother.
    Unfortunately I have noticed another issue. If I sweep up the pedal very slowly it doesn’t register in the volume map or on the “tip calibration” screen. It just stays fixed at whatever pedal position it was in before starting the sweep. If I give the pedal a quick twitch it jumps up to the proper value.
    I’m not sure if this is something about the pedal or about the H9000, but if someone has an expression pedal on hand I’d be curious if you can reproduce this behavior yourself. I’m taking about 10 seconds to go from one end of the pedal to the other.
