Home › Forums › Products › Stompboxes › H90 – Friedman IR-x Connections › Reply To: H90 – Friedman IR-x Connections
May 4, 2024 at 12:04 pm
#182134
You need to think about your signal flow and it’s chain…
You are going into the H90 input, out 1 to IRX in …. so far so good ….. You then have th eH90 out 3 going into the IRX SEND – that is an out going onto an out. It will NOT work this way. Then you have an IN going into an In. The IRX Return is to have a signal ‘Returnng’ into it.
I would place the IRX in the H90 loop and then you can place it anywhere in the H90s signal chain. Follow the instructions on the manual for adding a mono effect into a loop.
Cheers, <span style=”font-size: inherit;”>Jim</span>
