Home › Forums › Products › Stompboxes › H90 insert – any AD/DA conversion › Reply To: H90 insert – any AD/DA conversion
May 9, 2024 at 6:19 am
#182543
How much latency do inserts add exactly? Not including the inserted pedal!
In the manual it says Input -> Parallel -> Output = 3.8ms, Input -> Series -> Output = 4.5ms.
Does that mean that each Preset takes 0.7ms (in series) and therefore an empty lane, meaning just ADDA takes 3.1ms? Calculated like this: A/D=1.55ms + Preset A=0.7ms + Preset B=0.7ms + D/A=1.55ms
If that is the case, I guess using 1 insert would add 3.1ms. But would a second insert then add another 3.1ms when routed in series? Or does it stay at 3.1ms regardless?
