Home Forums Products Stompboxes H90 4 cable method Dual Routing failed Reply To: H90 4 cable method Dual Routing failed
#182680
Please provide more details about exactly how everything is setup (all of your connections between the H90 and the Friedman) and I can see if there is anything that could be causing the issue.
If you have confirmed that your H90 is in dual mode and audio is passing correctly on both paths, it sounds like the issue is possibly a setting on the Friedman or an error with your physical connections.
