Home › Forums › Products › Rackmount › no input meter on H7600 › Reply To: no input meter on H7600
#182720
flextone
    reviving this old thread since I’m experiencing a similar issue with an H8000FW I just received.The meter doesn’t seem to be responding at all, just the bottom line of LED’s are lit.
    The facts:
    – Balanced connection from a Metric Halo LIO8 interface to analog ins 1+2 of the unit
    – Playing a loud signal, around -10dbfs
    – Meters in the LIO8 show that what is returning to the interface is the same level as what is leaving
    – Meter lights up on start up
    – Meter responds fine when I crank the Pre-AD input level, but
    – I can crank up the output level from the interface so much that it clips the D/A and H8000 meter remains at the -40 mark
    – Tried different cables, same result
    Any ideas? Taylor 12k did you ever get the problem solved? I wouldn’t want to keep this unit without being able to internally gain stage properly.
    Thank you in advance! I am aware that the 8000 is no longer in production. Any help is greatly appreciated!
