Home › Forums › Products › Stompboxes › H9 in stereo effects loop › Reply To: H9 in stereo effects loop
#182728
aenlic
    It’s in the Pedal Settings, Rob. My final result was to leave that and the Bypass setting with the default setting.
    If you are NOT already using the H9 Control app, I strongly recommend it. Make sure you register your H9 before trying to connect, though… that is not documented, but without that, you’ll have trouble connecting.
    Enjoy!
