Home Forums Products Stompboxes H9 in stereo effects loop Reply To: H9 in stereo effects loop
#182730
Kill Dry is a setting that removes the dry signal entirely, and turns the mix knob into an FX level knob. This is useful when you only want the wet signal present, for instance when using wet/dry setup or using the H90 with an effects send. You may not need this setting depending on how you are using the H90.
