Home Forums Products Rackmount Seeking Neck Pickup Sound Reply To: Seeking Neck Pickup Sound
#182924
    It sounds like you are using some of the EQ45/EQ65 presets. These algorithms have an alternative version called “ST Compress > EQ45/EQ65” which adds a pre EQ compressor.
    You could also try the EQ Compress algorithm from the H9. The Leo to Les or JazGuitar presets might work for your setup.
