Home Forums Products Stompboxes H90 DC-block – High Pass Filter Reply To: H90 DC-block – High Pass Filter
#182952
tsternfeld
    The H90 does have DC-blocking filters in the hardware, but there is not much signal attenuation at 10 Hz.  If you need to reliably eliminate signals up to 10 Hz, I would suggest using a device that is dedicated to the task.
