Home › Forums › Products › Stompboxes › H90 Midi Thru + Clock from H90 › Reply To: H90 Midi Thru + Clock from H90
May 28, 2024 at 10:03 am
#182958
The current MIDI implementation on the H90 is it can either pass thru MIDI information, or transmit MIDI information, it cannot do both.
I would suggest that you either:
- Set the H90 to transmit and use the H90 as the clock source and also use it for sending PC and CC messages. OR
- Set the H90 to thru and us another device before the H90 as the clock source and PC/CC controller.
