Home › Forums › Products › Rackmount › Metronome Looper › Reply To: Metronome Looper
#182959
    The metronome algorithm cannot be synced to the H9000 tempo.
    Can you please elaborate on your looper setup? You can use tempo sync for any of the time based algorithms and that will sync them to the H9000 tempo. Why do you also need to have the metronome algorithm?
    You can use VSig to open existing algorithms, but the 9110 Looper algorithm from the TimeFactor is not available for the public to access. There are other looper algorithms from the H8000 that you can download and edit.
