Home Forums Products Rackmount Metronome Looper Reply To: Metronome Looper
#182966
    Thanks for the information.
    Do you need to audio reference from the metronome or is it just visual? When you use the looper algorithm, there is a transport display that shows the current state of the looper (rec/dub/what beat you are on). Can you use the transport as a visual guide instead of the metronome?
    If you need the audio from the metronome, you can use a DAW which can give you an audible metronome instead of using an H9000 algorithm. You can set the H9000 tempo mode to DAW, and open up Emote as a plug-in, then the H9000 and looper will be synced to your DAW.
