Home Forums Products Rackmount Open Expansion Card Slots for Cooling Reply To: Open Expansion Card Slots for Cooling
#183022
    The H9000 is designed with ventilation from the sides of the unit, and the fan helps regulate the temperature. As long as the sides of the unit are not blocked, there is nothing to worry about if you have no space above/below. I don’t think airflow from the expansion card slots would make much of a difference since there are already openings on both sides of the unit.
