Home Forums Products Eurorack Modules Sending Clock from Digitakt to Misha Reply To: Sending Clock from Digitakt to Misha
#183252
    If you press the shift buttons on Misha until you see the clock settings, you can use the Key knob to change the clock source to MIDI, and this should make Misha follow the MIDI clock and start/stop commands from your sequencer.
    Let me know if that works.
