Home Forums Products Stompboxes Insert volume affected by program wet/dry value Reply To: Insert volume affected by program wet/dry value
#183368
tsternfeld
The insert chain is part of the wet path of your program.  If you set your program mix to fully dry, that is essentially the same as DSP bypass, so the inserts will also be bypassed.
If you want a different behavior, you will need to instead work with the Insert Mix and individual A/B bypass and mix.
