Home › Forums › Products › Plug-Ins › SP2016 The phase is invertet › Reply To: SP2016 The phase is invertet
#183382
    To be more accurate, it’s only the first reflection of the early reflections that has a negative phase in relation to the input.
    It’s not necessarily recommended to reverse the phase of the SP2016 output, but if you like how it sounds and it works for your application, then go for it.
    You can also use the modern algorithms and these will not adjust the phase.
