Home Forums Products Rackmount H9000 Algorithm Combiner Reply To: H9000 Algorithm Combiner
#183597
    The only algorithms that are not available for download are some of our newer offerings, such as the H9 and H90 algorithms.
    You can download the GobiGuitar algorithm into VSig to edit, along with something else similar to SpaceTime. There are many delay/modulation/reverb combination algorithms that could get you into similar territory as SpaceTime. However, “combining” two algorithms in VSig may not be a simple task if you are not familiar with how VSig works or do not have a basic understanding of DSP.
    You should be able to edit any of the algorithms that operate in mono to be in stereo as well, but it will take some time and knowledge of how to use VSig.
    We have considered the possibility of allowing more algorithms to run in an FX Chain, or combining 2 algorithms if they are not too resource intensive, but this will require a good deal of work and I can’t promise if/when this would happen.
    I would suggest checking out the “Virtual Rack” algorithms, which are multi-FX algorithms that allow you to send MIDI messages to engage the different effects https://cdn.eventideaudio.com/manuals/h9000/2.0/content/appendix/algorithms/66_Virtual_Racks.html
    Thanks for your post!
