Home › Forums › Products › Rackmount › H9000 with two Dante cards › Reply To: H9000 with two Dante cards
#183644
gustebeast
    Did you end up getting the second card? I’m considering getting two cards but I want to double check that you can connect them with an ethernet cable, set up a connection in Dante Controller, then disconnect them from the rest of the network and still have them send audio back and forth via the pre-configured connection.
