Home › Forums › Products › Stompboxes › H90 in the loops of 2 amps at the same time ? › Reply To: H90 in the loops of 2 amps at the same time ?
July 9, 2024 at 10:37 am
#183654
Hi tbskoglund,
Thank you for your reply!
So the point Joe Cozzi is making above
‘Running stereo in a setup where both amps have different settings or drive structures is not recommended’
does somehow not apply to my setup? Just trying to wrap my head around this 😉
If I understand your reply correctly, you mentioned I can connect the OUTPUT of my Walrus to the INPUTS of my H90?
But isn’t the Walrus supposed to be put at the end of the signal chain because of its XLR’s?
Truly sorry, this is all quite new to me.
Thanks again!
Peter
