Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#184028
    … a long delay for ‘tronics/looping. 16 seconds or so (enough for four bars at 60bpm) would be perfect. Doesn’t have to be posh, vanilla will do! Thanks!
    Have you considered two UltraTap instances in Series with Length at eight seconds each?  One Tap, 100% wet (dry mixed in at the Program level), but otherwise vanilla settings?  That is, neutral values for many of its parameters.
    Yes, the ‘loop decay’ (individual Feedback around each instance, instead of the entire ‘loop’) is going to get a little tricky.  I mention it as UltraTap is my go-to for all sorts of Neapolitan bits ‘n’ pieces emerging from the distant past.
