Home › Forums › Products › Eurorack Modules › Mislabeled Third and Sixth Chord Inversion Labeling on Misha v1.1.2 › Reply To: Mislabeled Third and Sixth Chord Inversion Labeling on Misha v1.1.2
This is related to the discussion above. So I’ll add a note about it here.
In testing some more, I wanted to let you all know that I noticed a issue between what is produced via Midi vs CV as in the pitch is different.
Using the C Major scale and using the Chord option of Sixth the device states the notes are the following:
C E C
I’m assuing that would be C on CV1. E on CV2 and C on CV3
Via Midi I get the following notes produced:
E2 and C3 so there aren’t three notes transmitted via Midi only 2 of the three notes. And here that E is in the bass ideally we would have a C in the bass as well.
When I tested the CV outputs to a synth I get the following:
CV1 = C3
CV2 = E2
CV3 = C3
Hope this info helps with the discussion about the chordal aspects of Misha,
Thomas
