Home Forums Products Stompboxes H90 Freeze a sound Reply To: H90 Freeze a sound
#184089
    I just spent some time trying to recreate this kind of effect with PolySynth and UltraTap. It’s not quite the same, there is no auto latch or glide, but this can achieve a similar effect if you freeze a chord with PolySynth, then play another chord, then un-freeze and freeze again while that chord rings out. That sort of gives the morphing/glide effect.
    You can download and try the Program here: https://etide.io/UX3As
    You could also use the SuperEgo as an insert in the H90 and get a lot of great results that way.
