Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#184179
    That is correct. You can use auto engage to bypass the PolyFlex effect, and use the onboard footswitches for any other parameters such as effect bypass.
    Any 10-25k expression pedal should work fine. The Mission H9 pedal will work fine if you are ok with just the expression function.
    I am not aware of any future plans for Mission Engineering, I would suggest contacting them with that question.
