Home › Forums › Products › Rackmount › H3000 system exclusive format › Reply To: H3000 system exclusive format
Had a brief look this morning with my coffee.
First of all – that was a ton of work you did.
Second, I’m going to need more coffee.
Third – When I start dumping some of the sysex for the various programs, some of this will start to make more sense. I will try not to ping you about any of the specifics in that spreadsheet even though it’s only been 10+ years. 🙂
I’ve spent a chunk of time deciphering the PCM 80 bit-packed format as well as dumps from the Oberheim Cyclone, LXP-5, and some Waldorf products and write code as part of my day job, so all of this raw info is going to be a huge boost to start things off.
Yes – I tend to use my H8000FW a lot more than the 3000, but part of that is the eveNET remote for it. I’m hoping that I can put together a somewhat decent editor for the 3000 running on the Electra One MIDI controller hardware platform. We’ll see how that goes.
Again – much thanks for what you provided. The work involved is understood and appreciated.
