Home › Forums › Products › Rackmount › H3000 system exclusive format › Reply To: H3000 system exclusive format
#184395
jrichoux
    I’ve been digging around in my Max H3000 program in the interests of verifying the tables I shared. I don’t think that the parameter addresses are specific to a raw sysex dump but rather to a table that would be created after eliminating the first 18 bytes (the sysex command) and then converting the remaining bytes from ascii codes into hex numbers, etc. When I have some time I’ll check it out further. I might even be able to eventually format a proper sysex dump table.
    However I did test that onscreen parameter changes did go out to the device in realtime
    JohnR
