Home Forums Products Rackmount H3000 system exclusive format Reply To: H3000 system exclusive format
#184401
tmoravan
    John – I started trying to use the Parm sheet to see if I could get the H3000 to respond to an NRPN parameter change, but no luck so far.
    The implication from the spreadsheet is (for example) sending the NRPN of 4 changes the Right feedback value for algorithm 100.
    I tried various combinations of the NRPN byte messages with no success.
    If you could send one parameter string that is sent from the Max code that would go a long way to being able to initially talk to the 3000.
    The sysex parsing I’m saving for a bit later because that’s a lot of dump patch/decipher sysex, match things up, rinse and repeat.
    If you’d rather carry on follow-on discussion via email, I’m available at — tmoravan    AT   yahoo DOT com
    (no idea if forum software strips out/blocks actual email addresses).
    FWIW, no matter if our discussions are here on via email, my resulting efforts will be publicly available for people to use as desired.
