Home › Forums › Products › Stompboxes › H90 Routing Questions › Reply To: H90 Routing Questions
#184556
toumpouris
    Hey!
    Thanks a lot for the info, I will try to explain more in detail and regarding my setup.
    I am using the pedal in stereo in and stereo out from my RME audio interface, so Im using the totalmix software mixer as sends/returns, so I have the dry signal on a separate channel. I do not need the dry signal at all when processing through the H90, that’s the reason im using kill dry.
    When in series, I just need part of my pitch shifter to go into reverb and part of it to stay as is. When I try, all the pitch shifter goes into the reverb and I lose the pitch shifter.
    Is it possible?
    Thanks
