Home Forums Products Rackmount H9000 Scene Algorithm Load Pop Reply To: H9000 Scene Algorithm Load Pop
#184621
gustebeast
    I’ve tried it with Large Room2, GobiGuitar, DesertPercussion1, Instant Phaser MkII SpaceTime and Thru. All of them make the same pop. I also just tried replacing the algorithms using the normal drag and drop method instead of scenes, same pop. The key is that there needs to be signal flowing when the replacement happens since the volume of the pop is proportional to the volume of the signal.
