Home Forums Products Stompboxes How do I change to different lists from the H90 pedal itself? Reply To: How do I change to different lists from the H90 pedal itself?
#184646
jononotbono
    Ok, so to change lists from the pedal itself, you have to press and hold Programs and ROuting together, then the system menu comes up, then select global, then chose the list, then select it. Then the list has changed. Man, that took some work figuring it out 😂
    Surely a better way would be Press programs button, Use knob A and turn it to whatever list is desired. Then just press Knob A and have it be instantly selected?
    Anyway, this has been a very enjoyable conversation I’ve had with myself on here. Please feel free to delete the whole thread if necessary (is it actually possible as I can’t see any options).
    Jono
