Home Forums Products Rackmount H9000 USB Failure? Reply To: H9000 USB Failure?
#184685
    Sorry, I don’t have the information for what the root cause is, or if the other users issue is the same as yours. We can provide some more information via the support ticket if you like.
    I would not suggest that there is any reason why you should limit the use of the physical USB port.
