Further description of bug. This bug appears in the FX chain view, not the algorithm view. The name of the algorithm appears twice in this view. At the top of emote as well as in the signal chain where the actual algorithm is displayed on the grid. The top of the page (where you would click to edit the actual controls of the effect) changes as expected. The actual algorithm on the grid is the one that does not. In FX Chain view, select any algo with presets and expand the presets in the browser on the left. Bouquet delay has 7. When you load it, it loads up rosebud. Now double click around the presets. You should see the algo view change properly, but the ACTUAL one on the grid lag behind by one. When you see it do this, move the cursor anywhere near the algo on the grid and it will ” catch up” to the proper, current name.
