Home Forums Products Stompboxes H90 Stereo in (1/2) Dual Stereo out (1/2, 3/4) question Reply To: H90 Stereo in (1/2) Dual Stereo out (1/2, 3/4) question
#184906
tsternfeld
    You could do the first configuration in insert mode with the effects in parallel and a stereo insert positioned after whichever effect you want on outputs 3/4.  The second configuration could be done similarly (there are latency and polarity compensation options built in as well).
    The trick with insert mode is that you don’t need to have any return signals, so you can build in a lot of flexibility with split IO configurations.
