Home Forums Products Stompboxes H90 not receiving MIDI CC with PC from Boss ES8 Reply To: H90 not receiving MIDI CC with PC from Boss ES8
#184970
joecozzi
    I tried changing the Switch Mode to ‘Release’ but that did not make any difference for me.
    To be clear, the program change should happen “on press,’ while the CC value should be delivered ‘on release.’ In my experience, after the initial press, hold it for like a second before releasing in order to give the program time to load. I know this is not optimal, but we are looking at improving this process, nonetheless.
    I’m using the Space Spiral program and what I want to do is bypass it during the chorus and back on for the verse, I have tried this with both P Act/Byp and P Act/Byp (M) with different results. P Act/Byp requires 2 taps to enable/disable and my loops only require 1 tap. P Act/Byp (M) has less consistent results but the most common result is the first tap is ignored and then it works with 1 tap, so that puts it out of sync with the rest of my ES8 program.
    First off, it would be ideal to save the Space Spiral program in the active state it needs to be in from the start, which by default is “active.” If you need it to start out in a bypassed state, load the program, bypass it, and save it that way; now every time it loads the program it loads it bypassed.
    For individual control of a Program’s active state, it’s best to use P Act/Byp (M) where sending a value of zero bypasses and sending a value of 127 activates.
