Home Forums Products Stompboxes H90 not receiving MIDI CC with PC from Boss ES8 Reply To: H90 not receiving MIDI CC with PC from Boss ES8
#185017
kturner
I did a little more investigation on this today, I have video if you would like it but here is what I found.
It does not matter if I hold the button, am in Push or Release mode, or Patch Time change is increased.
When changing a patch on the ES8 – it sends the CC 1 clock cycle after PC and if there are 2 CC, the second one is sent 1 clock cycle after the first CC.
If the ES8 Editor is open, then there will be a SysEx command sent 3 clock cycles after the last CC.
If the H90 Control app is open, it will send a SysEx command 4 clock cycles after the Roland SysEx (or CC if the ES8 Editor is not open) and send another SysEx 4 cycles after the first SysEx and a third SysEx 45 cycles after the previous one.
I hope this is helpful.
Kevin
