Home Forums Products Stompboxes H90 not receiving MIDI CC with PC from Boss ES8 Reply To: H90 not receiving MIDI CC with PC from Boss ES8
#185042
    Hey, Kevin.  It sounds like PC + CC1 + CC2 are sent in very quick succession (2+3+3 bytes = a few mS + any overhead).  And yes – from reading that ES-8 classic Boss-style manual – it is either-or with a Push or a Release action, unlike the Morningstars.  The ES-8 appears to be a full-featured device, but I don’t have one here to test.  So these are speculative solutions that may / may not contribute:
    Expanding on my suggestion above.  Don’t use the Patch level Ctl 1-2 parameters.  Just send the PC, and use the Assign parameters to (theoretically) delay any subsequent CC messages.
    Assign
    • Src -> INT
    • Cate -> MIDI
    • Target -> CC
    • Min Max -> probably to the same value?
    • Ch -> 8
    • CC# -> appropriate CC number
    • Trig -> PAT
    • Tim -> vary this delay value 1-100 to find the ‘sweet spot’ for recognizing the CC
    • Crv -> FST, maybe LIN
    Target List
    • When Cate is set to MIDI – appropriate CC value
    If all else fails, you may be able to substitute E.CTL for the CC value(s).  Boss EXP 1,2 to H90 EXP1 and/or EXP2.  It’ll cost you one more TRS cable.
