Home Forums Products Rackmount H9000 and Pro tools HDX Card. Question and setup Reply To: H9000 and Pro tools HDX Card. Question and setup
#185444
GoldenRaven
    Ok, thanks
    Will check and try…
    So just to be clear,  if you use the HDX Card in the H9000 it is imperative to use the Loop Sync to have the H9000 working propertly.
    So Word Clock via  AES is not valid when using the  Pro Tools HDX Card?…only the Loop Sync?
